Stakeholders can now review the 4D sequence on the web, no install or powerful hardware required!
After upgrading an existing SYNCHRO project or starting a new 4D collaboration project in SYNCHRO Control, users will be able to review the 4D model in SYNCHRO Control. Changes made in SYNCHRO 4D Pro, will be synchronized to SYNCHRO Control automatically*. To review the 4D sequence, go to SYNCHRO Control and select the Schedule tab.
Some of the features of the viewer are shown below:
The 4D sequence can also be viewed in any of the Forms tabs in SYNCHRO Control
In addition to the tools available in the Schedule tab, the Forms tabs also include the following features:
*NOTE: Synchronization been SYNCHRO 4D Pro and SYNCHRO Control is not real-time. There may be a lag of more than 30 minutes between when a change is made to a schedule or model in SYNCHRO 4D Pro and when this change is visible in SYNCHRO Control. Therefore, SYNCHRO Open Viewer is still recommended if you need to view real-time changes made by SYNCHRO 4D Pro users.
NEXT: Synchronizing updated 3D Models
