Check to make sure that your machine meets the minimum requirements to run Synchro software.
Minimum System Requirements for Synchro 4D PRO
Operating System: Microsoft Windows 7 (x64), 8 (x64) ,10 (x64) or the latest
Processor: Intel ® Core i7-3840QM CPU @ 2.80GHz 2.80 GHz
Installed memory (RAM): 16GB (x64)
System type: 64-Bit Operating System
Pen and touch: No Pen or Touch Input is required
Display adapters: 1 GB graphics card (DirectX compatible)
Display adapters driver: Supported graphics card and drivers for HOOPs 20.x are at: http://developer.techsoft3d.com/hoops/hoops-visualize/graphics-cards/
Disk drive (program file): 1.3 GB hard disk space for installation files
Disk drive (project file): 1 GB for each typical project files
Display: 1 Colour display
Screen Resolution: 1280 x 1024 screen resolution
Ensure that your machine drivers AND/OR Windows updates are of the latest version:
(Please contact your internal IT team in regards for doing this updates)
Reset Options to Default
(This will reset all settings to factory default on this machine.)
Clear Old Registry Keys
How to clear SYNCHRO PRO Registry?
Setting Graphics Mode API
Network issues
It is important to not whether you are working with a private or Cloud/SWP Project. When working with a hosted project you may experience performance issues that relate to your internal network infrastructure. Our recommendation is to consultant your internal IT support when working in the environment.
Project Size issues
Depending on the size of your project you may see decreases in performance. It is important to make sure that you consider optimizing your project, our consultants at Bentley may be able to assist with guidance in this area.
3rd Party Tools - Plugins
When working with 3rd party tools such as Revit and Navisworks, be sure to check out our available plugins. Our plugins help to export your data into format that works best with SYNCHRO PRO. This can lead to better performance overall with our product.
