SYNCHRO 4D Pro and SYNCHRO Scheduler (SCH) are both complete CPM scheduling tools for construction. Therefore, an .SP file or an .SPX file can contain schedule data.
- Go to File tab, click Import > SYNCHRO project, browse to F05.sp file under .sp Files folder and click Open.
- Click Next button in the Import SYNCHRO project window. Note: You are NOT required to adjust Login or Password at this time.
- You can use the default settings to import all or choose Skip some of the attributes. Next, click Import button.
- You will be presented with the following window. Click Finish button to review the imported schedule in Gantt window.
- You do NOT need to save this .sp file for future exercises, you can close the project or exit SYNCHRO directly.
