SYNCHRO 4D Pro 2023 (v6.5.3) release announcement
Quick links:
Upgrading and Downloads:
If you have existing cloud-hosted 4D SYNCHRO Control projects, see the detailed instructions on upgrading cloud-hosted projects from 2021 (v6.4) to 2023 (v6.5)
If you are starting your first cloud-hosted SYNCHRO Control project, see Collaborating on a cloud-hosted 4D project.
Click the links below to download the latest version or visit Software Downloads in the Bentley CONNECT Center.
 SYNCHRO 4D Pro   SYNCHRO Scheduler SYNCHRO Open Viewer    SYNCHRO Plugins
Note: Codec x264vfw - H.264 was removed from SYNCHRO 4D Pro 2022 (v6.5.1.5) installer.
If needed, install this codec separately from here: x264vfw download | SourceForge.net and select it for animation export.
Minor Improvements
•Third-party package upgrade for security vulnerabilities
Bugs squashed
•  Certain geometry do not display when switching to iray mode
•  Fixed for task filter by Name/ID
•  Some dwfx textures are missing in 4D Pro
•  Notes and Documents window does not display any project data
•  Created Resource Group Code does not appear in the Codes list when created for the first time
and more...
Back to Top
Resources
  1. Help documentation: press F1 to access directly in the product
  2. Visit Bentley LEARNServer for online courses
  3. Training and Learning Resources
  4. System Requirements
Contact Details
Back to Top
