SYNCHRO 4D Pro 2023 (v6.5.2) release announcement
Quick links:
Upgrading and Downloads:
If you have existing cloud-hosted 4D SYNCHRO Control projects, see the detailed instructions on upgrading cloud-hosted projects from 2021 (v6.4) to 2023 (v6.5)
If you are starting your first cloud-hosted SYNCHRO Control project, see Collaborating on a cloud-hosted 4D project.
Click the links below to download the latest version or visit Software Downloads in the Bentley CONNECT Center.
 SYNCHRO 4D Pro   SYNCHRO Scheduler SYNCHRO Open Viewer    SYNCHRO Plugins
Note: Codec x264vfw - H.264 was removed from SYNCHRO 4D Pro 2022 (v6.5.1.5) installer.
If needed, install this codec separately from here: x264vfw download | SourceForge.net and select it for animation export.
Improvements for Cloud-hosted 4D project through SYNCHRO Control
1.
Support textures and materials from NWD source  - Textures and Materials from iModel using NWD connector are now rendered correctly in 4D Pro
2Support German language characters in .sp file – users can now upload .sp file that contains special German characters as Control project for cloud collaboration.)
Back to Top
Major Features
1.
SYNCHRO 4D Pro / SYNCHRO Scheduler / SYNCHRO OpenViewer are now certified with Windows 11.
2.
Import and synchronize from P6 XML – Improves user experience when importing and synchronizing from P6 XML. Also reduces crashes, time of import and synchronization
3.
Upgrade plugins to support Revit and Navisworks Manage/ Simulate 2023 and 2024
4.
3D Interoperability updates
  • ACIS: up to 2023
  • AutoCAD: R14 - 2022
  • Autodesk Inventor: up to 2024
  • CATIA V5/V6: Up to V5_6R2023
  • Dassault Interchange Format: Up to V5-6 R2019 (R29)
  • Navisworks: 2017-2024
  • Parasolid: up to v35.1
  • ProE/Creo: Pro/Engineer 19.0 to Creo 10.0
  • Revit: 2017-2024
  • Rhino: 4, 5, 6, 7
  • SolidEdge: V19 - 20, ST - ST10, 2019 to 2023
  • SolidWorks: up to 2023
  • UGS JT: up to 10.6
  • Unigraphics NX: V11 to v18, NX to NX12, NX1847 Series to NX2212 PRT Series
5.
Updates to ProjectWise integration
Back to Top
Minor Improvements
1. Updated Help documentation and corrected Script examples. .
2. Synchronization enhancement through spx for Microstation - reduces time for synchronization on large projects.
Back to Top
Bugs squashed
Edit as Assigned, 3D Path, 3D Subdivision and Growth simulation of Appearance Profile doesn't work for some objects exported with Revit plugin after upgrading to 6.5
Fixes for crashes on "Reschedule selected" on specific project
Fixes for multiple crashes while selecting all Resource Groups, etc. on specific project
Cannot hide or isolate selected 3D objects when working on specific Control project
Exporting P6 XML file from 4D Pro fails to open in P6
Error when merging subdivided 3D element
Links are not displayed in Successor column in Tasks table
Conducting rollback causes all transactions to be rejected
Updating multiple Resources statuses in 4D Pro causes rejected transactions
Camera is far away from model after exporting to iModel
Error when opening Help document from Options when language set to other than English
Issues with text display when Backplane Culling is enabled and double precision rendering disabled
Project order in projects list is incorrect when doing import/export iModel
Imported 3D object is not visible in 3D view when "Load 3D objects to memory" setting is selected
Number of Tasks imported from P6 XML  doesn't match with the count shown in import output window
Forms content (Daily Logs, Observations, RFIs, Issues) is not displayed in 4D Pro on specific project
4D Pro doesn't start with upcoming PW Explorer version 23.02.00.12 installed
Geometry imported to 4D Pro are missing in Control
Resource Unit Format setting should not calculate Units for Material type Resource
The model is not loading in the Field app on specific project
3D import settings are applied only on next import
Not possible to update resource status date to the same date in resource status history
6.5 does not correctly load plugin settings from 6.4
and more...
Back to Top
Resources
  1. Help documentation: press F1 to access directly in the product
  2. Visit Bentley LEARNServer for online courses
  3. Training and Learning Resources
  4. System Requirements
Contact Details
Back to Top
