| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
Sensor details shows a detailed chart for a specific sensor. By default the a 3 month signal history will be read.
The chart displays initially a time-window of 2.5 days back into past to 12 hours into future with the range-slider below the main graph turned on. This view is particularly useful to monitor network parameters and to easily spot any anomalies (that can represent bursts, leaks, tank overflows, pressure problems, maintenance works, etc.) in real time. The pattern confidence bands are represented by a grey band, while real (re-sampled) values are represented as a black, red or orange circles. Whenever real data (re-sampled) goes outside the pattern confidence bands (above percentile 95 or below percentile 5 of the pattern), an outlier is identified and the real value is color coded with a red circle. The user has also the option to navigate in the time history series to understand past behaviors or have access to future expected behavior (short-term forecasts), by moving the range-slider below the main graph.
Note: The user can navigate to the sensor details from the Sensor Status or Sensor Overview pages, by clicking in the name of the sensor.
The name of the sensor is displayed above the graph, in the upper left corner. The user can easily switch between different sensors by directly clicking on the down arrow located on the right side of the sensor name.
The pattern confidence bands are represented with a grey color. The Pattern drop down lets the user select the time period for which the confidence bands are based.
The user has the option to define the historic time range to be used to compute these pattern confidence bands: last month, last 2 months, last 3 months, last 6 months or last year of data. If there is not enough historical data to compute the pattern confidence bands an informative message is displayed, and only real (re-sampled) values are shown. Clicking on this message removes the message. Patterns can be customized by the user in the Administration page, under Settings > Pattern.
For more information about patterns or forecasts, please click here.
Specifies on the one hand the rate at which raw signal readings are re-sampled (15min, 1hour, daily) and on the other hand how the sensor information is charted.
All 15 minutes values and hourly values are evaluated looking backwards. For example if the value at 9h15 is 10 l/s, this represents the re-sampled value from 9h00 to 9h15. If the hourly value is 20 l/s at 10 AM, this represents the re-sampled value from 9 AM until 10 AM. All daily values are evaluated for the specific day that is being displayed. For example if the value for day 10th is 20 l/s, this value is calculated for the time period between 00h:00mm and 23h:59mm of day 10th.
The user can directly create an event based on the graphs observations, by clicking in the "Create Event" button. Created events will be displayed in the graph and also automatically be saved in the Active Events list. Events created with category meter failure will be displayed in the graphs with a red cross icon while all other event categories will be displayed with a purple symbol. To define the right event duration make sure before clicking in the create event button, to maximize the main graph to the catch all the event period.
Editing the event
The event can also be edited after creation, such as the duration and other fields, by directly clicking in the event symbol, to access the event detail graph - workflow 1. In that case update the event by using the side panel, image below.
Another workflow is to go the active Events list and search for the specific event and manage from there. Please note that if the event was created with the status closed, you will need to specifically filter for the closed events in the active Event list.
Adding manual events like meter failure events might be important to have reliable water balance calculations and also a correct gap filling for the zones. More information here - Zone Gap Filing: Estimating missing or wrong data and Water Balance Calculation.
By clicking in the compare button the user will be redirected to the comparison page where he will be able to simultaneously compare in the same graph any user defined variable. By default, the selected current measurement and sensor will be already displayed and populated in the Comparison page.
Click on the visibility button, under the graphic tools, to add model results (represented with a blue line) and raw data (represented with a green line) in the graphs. More information below.
Use the graphic toolbar to control the display of the charts shown on the sensor card, with the possibility to add additional information:
| Entry | Description |
Turn on/off: - Legend of the graphs - Signal data - Events highlighted in the graphs (with the additional flexibility to display only active events or all events) - Statistics (or patterns) - Current time marker - Raw Data Raw data is represented with a green line and corresponds to the original time series data that is being collected from the origin data sources into WaterSight, without any type of treatment and processing. And usually with a very short time step (every minute or every 5 minutes). More information about raw data cleaning and resampling can be seen in this article - Patterns and Demand Forecast calculation - Model Results Model results are displayed with a blue line and correspond to the values obtained from the real time hydraulic model that is running in WaterSight for the sensors location. To have the model results displayed here it is required to have SCADA signals and SCADA elements configured in the uploaded WaterGEMS model and mapped to the right model elements. More information can be found here - Preparing WaterGEMS model for real time simulation in WaterSight.
Range slider - Turn on or off the time range slider below the main graph Full y-Range - Y axis will adjust automatically to include the maximum value registered Time range - Define the time period included in the range slider below (last 3 months, last 6 months, last year, last 2 years). User will be able to navigate in the time series history, for the period defined here. |
| Download data that is being displayed on graphs (PNG or CSV format) | |
More graph configurations: spike lines, data tooltip and font size.
| Field | Description |
| Id | Scada ID/Tag of the sensor |
| Type | Kind of measurement |
| Status | Status obtained from number of signal readings in the selected signal time range and the expected number of readings. |
| Latest | Timestamp of most recent signal reading |
| Minimum (p05) | Percentile 5 of the historical time period defined by the user (default is last 3 months), for the integration type time-series defined. |
| Median (p50) | Percentile 50 of the historical time period defined by the user (default is last 3 months), for the integration type time-series defined. |
| Maximum (p95) | Percentile 95 of the of the historical time period defined by the user (default is last 3 months), for the integration type time-series defined. |
| Minimum/Median |
Ratio of "Minimum (p05)"and "Median (p50)" of the of the historical time period defined by the user (default is last 3 months), for the integration type time-series defined. |
Note: When a sensor is recovering from a long period without data, the first few weeks may have patterns that do not look intuitive. Factors to consider when interpreting patterns include:
Figure 3 - Special case when very few historical data is available.
Sensor Data Aquisition Requirements
