| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
This page is used to compare actual pump performance to expected pump performance. It can be used to identify pumps that are operating inefficiently, pumps in danger of cavitation, and pumps that are degrading in performance which might require maintenance.
The back arrow navigates to the previous page. Clicking on the down arrow expands a list of all pumps. Select any pump to view the associated graphs.
By default, a single series showing operating points from the previous 7 days is displayed. The Manage Series option allows the date range to be edited, as well as adding additional series with different time periods for comparison. This is particularly useful to evaluate whether a pump is degrading over time. The trash icon will remove the series.
The color for each series may be adjusted by clicking on the series color.
If the pump is a Variable Speed Pump, and the graph option is set to view speed series, the series options have a single date range for all series, and allow multiple series with different speed ranges.
Select which graphs to display: flow-head, flow-efficiency, flow-power.
All sensor raw data is resampled to a common 15 minutes time step, and one operating point is displayed for each time step in the specified time range. If a status signal is configured, operating points will not be displayed for time steps where the pump is off.
Information about the pump such as the SCADA signals and Factory Curves are configured in the Pump Configuration page. Each graph will show as much information as is available. Graph elements that depend on information which is not available or not configured will be omitted.
The Head graph shows the pump head vs. flow curve, together with pump operating points (flow vs head). Pump flows are obtained based on the pump flow SCADA signal. Pump heads are calculated based on the suction SCADA signal and discharge SCADA signal, which can be either pressure or level signals. If the flow or discharge signals are not configured, the operating points will not be calculated. If the suction signal is not configured, the suction pressure will be assumed to be 0.
The Efficiency graph shows the pump efficiency vs. flow curve, together with pump operating points (efficiency vs flow). Pump efficiency is calculated based on pump SCADA flow, calculated head and SCADA power signal. If power signal is not available, estimated values are calculated based on actual pump flow, efficiency curve and motor efficiency.
The Power graph shows the power vs. flow curve together with pump operating points (power vs flow). If no Power signal is configured but an efficiency curve is available, the power points will be estimated by calculating the water power from flow and head and adjusting based on pump, motor, and variable speed efficiencies.
If the current pump is a Variable Speed Pump, additional options are available (see also the discussion below on Variable Speed Pumps) :
Use the graphic toolbar to control the legend and display of the charts shown on the pump card.
Average performance variables for the period defined under Manage Series. By default, last week period is considered. If the user changes the period, automatically all average performance values displayed are updated to reflect the new selected period. If multiple series are selected, the values are related to all periods defined.
Real time values for each pump: flow, head, efficiency, power and speed. Efficiency values are calculated based on pumps flow, head and power.
Sensors associated to the pump (defined in the administration). Clicking directly on the name of each sensor will directly redirect the user to the detailed graph of that individual sensor.
In case there is not sufficient data to calculate the pump operating points for the defined time period (sensor data missing), an orange message is displayed informing the user that there is not sufficient data available. In case there is data but the pump status or flow indicates the pumps is off, an informative blue message is displayed informing that the pump is off for the defined period.
The Design Point is an operating point typically defined prior to selecting a pump to install and represents one operating condition that the pump is expected to be able to satisfy. It may or may not fall exactly on the Factory Curve, as sometimes the pump that is installed does not exactly meet the design expectations.
The Factory Curve for head is provided by the pump manufacturer. This represents the expected behavior when the pump is operating at full speed. The colored points represent the actual operating conditions and are calculated based on:
Interpreting the head curve graph:
In case there is not sufficient data to calculate the pump operating points for the defined time period (sensor data or pump curves missing), an orange message is displayed informing the user that there is not sufficient data available. In case there is data but the pump status or flow indicates the pumps is off, an informative blue message is displayed informing that the pump is off for the defined period.
The Best Efficiency Point is the flow rate at which the pump is most efficient when at full speed. The Factory Curve for efficiency is provided by the pump manufacturer. This represents the expected behavior when the pump is operating at full speed. The colored points represent the actual operating conditions based on SCADA values. Each point is represents one 15 minute time step.
For the flow-efficiency operating points those are calculated based on the following:
Note: Currently, the Factory Curve represents the pump efficiency, whereas the operating points represent wire-to-water efficiency including the pump, motor, and variable speed drive. Therefore, the operating points are expected to display lower than the Factory Curve.
Interpreting the curve:
The Factory Curve for power is provided by the pump manufacturer. This represents the expected behavior when the pump is operating at full speed. The colored points represent the actual operating conditions based on SCADA values (actual pump power and flow). Each point is represents one 15 minute time step.
If no power signal is provided the following assumptions are made:
Note: Currently, the Factory Curve represents the pump power, whereas the operating points represent wire-to-water power including the pump, motor, and variable speed drive. Therefore, the operating points are expected to display higher than the Factory Curve.
Variable speed pumps can change the shape of the Head Curve by operating a reduced speed. This allows behavior such as operating at a fixed flow rate over a range of head conditions, or adjust the flow rate to maintain a constant downstream pressure. Variable speed pumps are often able to reduce energy costs by consistently operating near the best efficiency point over a range of conditions, or by reducing the flow rate without requiring throttling valves that waste energy.
For variable speed pumps the effective head curve that the pump operates on is variable and depending on the pump speed, as shown below.
In WaterSight only the full speed factory curve is displayed (in example above it would correspond to the pump curve for the speed = 2850 RPM), therefore most of the time the pump operating points will not align with the full speed Factory Curve even when the pump is in good condition, because the pump might be operating at lower speeds. The points may display in a horizontal line underneath the full speed curve (indicating a fixed head setpoint), or a vertical line under the curve (indicating a fixed flow setpoint), or some other pattern.
In order to evaluate whether the pump is in good condition, the actual operating points can be normalized using the Pump Affinity Laws to show what the flow and head would be if the pump was operating at full speed. This requires a Speed signal and the full speed value to be configured in the Pump Configuration page. Use the Normalized option to toggle between normalized and normal display. This option is only available for Variable Speed Pumps (note: if this option is not displayed make sure that in the administration the pump is set to variable speed pump).
In the example below, two series for the pump have been defined. Each is for the month of February, one year apart.
With the normal display showing the actual flow and head (graph on the left), we see a vertical line indicating the pump is holding a constant 300 gpm over a range of head conditions. The points look the same for both years. The points are well below the factory curve, but for a Variable Speed Pump that does not indicate the condition of the pump. Under the normalized view (graph on the right), it can be seen that under full speed the pump would be operating below the Factory Curve, and that of the condition of the pump has degraded over the course of the year. Although the degradation in pump condition has not yet impacted the observed performance, it may be worth performing preventative maintenance and identifying the cause of the issue.
Another example below for another variable speed pump. On the left showing the actual operating points compared with the full speed curve (on the left) and on the right using the normalized option to display the operating points as if they were operating at full speed.
To check the real operating points for each pump speed, the user should disable the normalized option and select the option "Speed" under "Show series as". Example below shows the different actual operating points for the different relative speeds.
Variable Speed Pumps Efficiency
To calculate the efficiencies for the VSP pumps and in case the power signal is not available (and assuming that flow, head and efficiency curve is defined) it is required to have also defined the speed efficiency curve (in that case efficiency values will be estimated) and the full speed value (the value that the Pump Speed Signal will return when the Variable Frequency Drive is operating at full speed). If the speed efficiency curve is not available, the user can assume a linear speed efficiency of 97% - one of the benefits of VSPs is that they can maintain high efficiencies even at different speeds.
The pump signals configurations and other are characteristics done in the pumps administration page. Two different cases may exist:
WaterSigth can automatically handle and calculate operating points for each individual pump for both use cases 1 and 2. More information here.
Prioritizing Pumps for Replacement
