WaterSight - Learning Resources Guide
New User
If you're new to WaterSight, an overview can be found at This is WaterSight.
Also, new user training can be found in this video: OpenFlows WaterSight: Complete Solution Walkthrough
Administrator Guide
If you are an Administrator setting up the Digital Twin for the first time, start at the New Administrator Guide.
Context Sensitive Help
See the Context Sensitive Help for a list of help topics by each page in WaterSight.
TechNotes and FAQs
This is a list of TechNotes and frequently asked questions. If you have a question, check to see if it's been answered here.
What is New in WaterSight
A list of the articles that describe the latest functionalities in WaterSight can be found here.
Additional Resources
PowerBI Guide: A  guide on how to create and add PowerBI reports into WaterSight.
WaterGEMS Setup Guide: Preparing a WaterGEMS model for real time simulation in WaterSight. Includes a video with a detail demonstration
OFOSC and RestAPI Detailed Guide: A guide on how to set up and configure the connection in order to automatically bring time series data into WaterSight. A brief summary containing the main requirements can be found here - Sensor Data Acquisition Requirements. For more complete detail, please ask your Bentley point of contact for the OFOSC and RestAPI Detailed Guide.
Sensors Quick Guide: Quick guide on how to add and update new sensors
Pump Configuration Guide: A quick guide on how to configure pumps in WaterSight.
If you have a question that isn't covered by any of the above resources check here.
