Product(s): | Hevacomp Netsys | ||
Version(s): | V8i (N/A) | ||
Environment: | N/A | ||
Area: | N/A | ||
Subarea: | N/A |
While the Netsys program does not consider any additional drop pressure for grilles, etc, the calculation does consider a k value of 1 to account for discharge pressure. This accounts for air coming from a large space to a small space (for e.g. room > duct (supply) or duct > outside (extract).
Velocity Pressure is calculated as follows:
VP = ½ ρV²
Where:
VP = Velocity Pressure
ρ (Rho) = Density of air*
V = Calculated velocity in duct section
*approximately 1.2kg/m³, but adjusted for the temperature provided in the System Marker
Consider we have a velocity of 10m/s in a duct section, and an air density of 1.2kg/m³
VP = 0.5 x 1.2 x 10² = 60pa
