| Product(s): | Hevacomp Mechanical Designer | |
| Version(s): | V8i (N/A) | |
| Environment: | N/A | |
| Area: | N/A | |
| Subarea: | N/A | |
Pipe headers can be defined for flow pipework in Netsys
Method
- Place the header first and draw your pipes into it.
- The incoming pipe should be draw into the center, then your outgoing pipes can be added in.
- Be careful placing pipes as they can snap to each other rather than to header.
- Drawing to the center of the header is fine, but may appear confusing.
- If your pipe connects correctly to the header, the connection will be highlighted with a green circle.
- If your pipe connects to another pipe rather than a header, it will be highlighted with a light green circle.
- If the pipe doesn't connect to the header or another pipe section, the end point will be highlighted with a black circle.
- Headers can be resized in System Builder, but not in Netsys
