Product(s): | Bentley Hevacomp | ||
Version(s): | V8i (N/A) | ||
Environment: | N/A | ||
Area: | N/A | ||
Subarea: | N/A |
It Is possible to set up Bentley Hevacomp software to make the transition from using it in the office to using it in the home as easy as possible.
These methods require a client only installation of Bentley Hevacomp software.
Regardless of where projects are stored there should be a Hevacomp Projects on the root of the C:\ drive or in your Documents folder.
This folder may not contain projects, but it does contain some control files and information about the software. As most companies usually store project files on a server, it is likely that the software is currently set up to do this. When disconnect from the network, this will cause issues.
The following steps will help with setting up home and office modes, and transitioning between them.
The following folders should now be extant on the C:\ drive,
and you software will be set to 'home' mode:
Hevacomp Projects | Hevacomp Projects (home) | Hevacomp Projects (work) |
Copy the contents of Hevacomp Projects (work) into Hevacomp Projects
Copy the contents of Hevacomp Projects (home) into Hevacomp Projects
You should consult with your IT department as to the best method of making projects available to run in Home mode and also how best to get them back into your system afterwards.
This information is provided as reference only.
