| Product(s): | All Hevacomp Products | ||
| Version(s): | V8i (25) | ||
| Area: | N/A | ||
| Subarea: | N/A |
The final service pack (update) for Bentley Hevacomp V8i (v25) is available for download from the Bentley website.
Download privileges are required to obtain this software. If you do not have these privileges,
then the Bentley Website administrator for your company can either download on your behalf
or provide the privileges to your own log in if appropriate.
From the Bentley Systems website, click on Support.
Select the Go To CONNECTION Center option.
At this point you will need to log in. Note that if this step has been taken previously, or the "Remember me" option has been selected, then this step may be skipped.
Once logged in, click on Software Downloads to access the Software Fulfilment site.
On the Software Fulfilment site, select the Brand option, and then Hevacomp from the drop down list.
If "Hevacomp" doesn't appear, you may need to de-select the Connect Edition filter
Once Hevacomp is selected, an extensive list will appear showing all available Hevacomp downloads, including all Hevacomp Content and Hevacomp license types.
Select your Hevacomp license type from the list, for example, Hevacomp Mechanical Designer:
Click the download icon The Download will commence upon accepting the Terms of use
You may see that dependencies are also selected. If you are just applying the final update, you will not need these extra files.
This file will update a Version 25 installation to the final version
Once the file is successfully downloaded, right click on it choose to run as administrator.
