Pipe sizing - Pipe diameters and insulation thickness
 Product(s):Hevacomp Mechanical Designer
 Version(s):V8i (version number)
 Environment:N/A
 Area:N/A
 Subarea:N/A
You may wish to consider pipe ranges in your project. This spreadsheet will assist with comparison.
Ensure you are logged into Communities, then click this link to access the spreadsheet.
