Product(s): | Hevacomp Mechanical Designer | ||
Version(s): | V8i (N/A) | ||
Environment: | N/A | ||
Area: | Netsys | ||
Subarea: | Ductwork |
Whilst designing a ductwork system it may be required to connect a ceiling diffuser to the underside of a plenum box. Diffusers do not snap to plenum boxes so a short length of duct is required to make the connection. This video shows the method for achieving this.
