1) Open a MicroStation-based product.
2) Select a workset that is assigned to a ProjectWise Project
Note: The assigned ProjectWise Project needs to be one where you have been granted ProjectWise ContextShare's "Use" permission.
3) Open a DGN file.
4) Open the "Reality Mesh Attachments" dialog and click "Attach Reality Mesh".
5) In the "Attach Reality Mesh" dialog, click the "ProjectWise ContextShare" button.
6) The ProjectWise ContextShare dialog lists all the Reality Data of type "Web Ready 3D Scalable Mesh" that are associated to the ProjectWise Project. Select one and click "OK" to attach it to the "Reality Mesh Attachments" dialog.
Related:
