Product(s): | Hevacomp Legacy | ||
Version(s): | V8i | ||
Area: | Installation |
The latest version of the Bentley Hevacomp installation consists of three parts:
Should you require these installation files please log a Support Case.
We advise logging on as Full Administrator and disabling User Account Control before following the steps below.
Ensure you have all three installation files. All three must be installed for the software to function. These are available for download as detailed here.
Run (right-clicking and selecting Run As Administrator is advised) the Hevacomp V8i installation setup file:
After the initial stages of the installation are complete the following dialog will appear:
In this dialog, set the location for the software and data files to be installed to. It is advised that these be left as default.
Click on Next to complete the installation.
At this stage you will need to activate the software. For details on locating the activation key, please see this document.
Note: should you wish you can click cancel on the activation screen to skip it, and complete the installation. The software will run in trial mode and you can activate at a later stage.
Next, apply the latest Update to the installation by running the below file:
Finally, the latest Content pack should be installed by running the content installer below. Follow the prompts to complete the installation.
Please note:
