| | Product(s): | ContextCapture | |
| | Version(s): | 10.00.00.00 | |
| | Environment: | Windows 10 64 bit | |
| | Area: | N/A | |
| | Subarea: | N\A | |
Different editions & their licensing options
What are the License Options for ContextCapture
Licenses can be purchased for each of the following modules:
ContextCapture
Includes ContextCapture Engine & ContextCapture Master. For single workstation installation up to 100 Gigapixel imagery dataset only,
ContextCapture Centre
Includes ContextCapture Center Engine & ContextCapture Center Master. Unlimited imagery dataset capacity
Can be used in a cluster environment. As many installations as desired are allowed per cluster however a separate license is required for each installation. A minimum of one CantextCapture Center Master license is required per cluster
Used for a cluster environment. Multiple installations can be applied but each workstation will require a separate license.
http://communities.bentley.com/products/3d_imaging_and_point_cloud_software/w/wiki/24451.what-are-the-different-editions-of-contextcapture
| | Original Author: | Felix James | |
