iTwin Capture Mobile is an intuitive mobile application for reality capture. Even if you are a non-expert user, you can easily perform good acquisitions, thanks to real-time feedback, in augmented reality, about data quality and completeness. Then upload the data for processing in Bentley’s cloud. With iTwin Capture Mobile, you can quickly produce 3D models of existing conditions to provide precise real-world context that you can leverage during all phases of an asset lifecycle.
| Getting Started with iTwin Capture Mobile |
