Important note: with this new licensing method, you will need to sign in to the CONNECTION Client (included with installation of CulvertMaster). If you do not currently have an account that is properly linked to your organization, please contact your Site Administrator, who can add you.
Note: The Help > About window in CulvertMaster CONNECT Edition currently does not include the license status. To check your license status, check the "Product Status" tab of the Bentley Licensing Tool (accessible from the Windows Start menu).
Fixes to User-reported Issues
This release includes all patches from the previous release for user-reported issues, plus updates to the Help menu item links.
Project Compatibility
Projects saved in CulvertMaster CONNECT Edition are compatible with previous releases. Meaning, CulvertMaster version 3.3 can open a project saved in CONNECT Edition.
Silent mode syntax
This version uses newer installation technology similar to the CONNECT Edition of the other OpenFlows products, which use a /q switch for silent mode. See: Performing a silent installation
