![](cff32df61b710250dc6db99f034bcb4c.iix)
AutoPIPE XM SR1 version 09.00.00.08 (June 5, 2007)
Analysis
- Add option to activate dampers in the wind cases
Interoperability
- Save as version 8.6 & 6.3 DAT files from version 9.0
- Export AutoPIPE model and support loads to STAAD
- Write Caesar cii neutral file
- StressISO: Add decimal control to Anchor & Support loads and stresses
- Save as version 8.9 DAT files from version 9.0
Modeling
- Add option to input numeric point names only
- Option to paste using actual coordinates relative to origin
- Automatically update point names defined in rotating equipment data
- Automatically update point names defined in steam relief load data
- Automatically update point names defined in fluid transient load data
- Automatically update 'connected to' point name defined in support data
Reports
- Add minimum 2 page description option to model input listing
Piping Codes
- Update ASME B31.1 2005 addenda code
Libraries
- Add Haynes 556 material to ASME B31.3 library
- Add Al-6XN material to ASME B31.3 material library
- Add ductile iron A395 and A571 to ASME B31.3 material library
- Update Euromat library properties down to 0 degC
- Add China Petrochemical Spring Manufacturer
- Extend A790 S31803 to -20F in ASME B31.3 library
- Add A269 Stainless material grades TP304, TP304L, TP316, TP316L to B31.3 library
- Add A335-P92 to ASME B31.1 material library
- Add B423 & B705 NO8825 materials grades to ASME B31.3 library
- Add copper and socket weld schedules CT2 and SKT to component library
- Add B88-C12200 copper pipe material to ASME B31.3 library
- Add 6061, 5083 & 5154 aluminum materials to B31.3 library
- Add STAAD.pro structural section libraries
- Add Chinese GB material library
- Add B619 UNS N06022 Hastelloy C22 material to ASME B31.3 library
Post Processing
- 'E827-3. Buffer Size Exceeded' for interactive code scan on large model
- Add user pref flag for use of automatic sustained load margin check
System Requirements
Platform: AutoPIPE is designed to run on the following platforms/operating systems. At a minimum, your computer should meet the minimum requirements for that system; for example, the amount of RAM required by AutoPIPE depends on the RAM requirements of the environment in which you will be working:
- Windows XP Professional SP2 or later
- Windows 2000 SP4 or later
Hard disk space: Approximately 139 MB
Video Graphics Card: OpenGL 3D graphics supported
Processor: Intel Pentium-based PC 486 or higher
RAM: minimum 128 MB
Internet: Microsoft Internet Explorer 6 or greater
See a complete collection of Readme notes at:
http://communities.bentley.com/products/pipe_stress_analysis/m/pipe_stress_analysis_gallery/269426.aspx
