| Version(s): | through 08.11.13.140 | ||
| Area: | Administration Features | ||
| Subarea: | Options |
How do I make gauge and color or other wire properties appear along with the wire numbers on schematics?
Predefined "Wire Tag (only)" and "Wire Tag (complete)" profiles or existing custom profiles can be loaded by clicking the Load Profile button. The "Wire Tag (complete)" profile includes the gauge and color in addition to the wire number. Custom profiles can be created using the expression builder in that dialog and saved with the Save Profile button. Saved profiles can be loaded in other projects.
Starting with Promis.e and Bentley Substation V8i SELECTseries 7, different saved profiles can be selected for use on different branches in [[Wiring Manager]]. The profile specified in the project options will be the profile used by default. It is now also possible to display the properties of every branch represented by a single logical line.
