Access Bentley Licensing Tool
The Bentley Licensing Tool (previously referred to as the License Management Tool or LMT) is used to activate Bentley software and check licenses in or out. The user is prompted to activate Bentley software upon installation, but there may be a need to access the licensing information after the product is installed. This article will walk the user through a couple of ways to access to the Bentley Licensing Tool from inside the OpenUtilities Map product.
  1. Open the Bentley OpenUtilities Map product and select a DGN file to open. Once the DGN file is open, the ribbons and tools will populate.
  1.  Select ‘File’ in the upper left-hand corner of the application.
  1. This will open the Ribbon that displays the File menu options seen below.
  1. Select ‘Tools’ and all of the available Tools will be displayed.
  1. Select ‘License Management’ and the Bentley Licensing Tool will be displayed.
  1. Alternatively, after Step 1, go to the Search Ribbon on the upper right-hand corner of the application. Type in ‘License’ in the search bar and select the ‘License Management’ tool that is listed in the results.
  1. This opens to the same Bentley Licensing Tool.
