| | Product(s): | MicroStation | |
| | Version(s): | CONNECT | |
| | Environment: | N\A | |
| | Area: | Installation | |
| | Subarea: | General | |
During the installation of MicroStation CONNECT Edition the Companion Feature ' Descartes ' was selected by mistake, which may lead to unwanted usage being reported. This article advises how the Descartes Companion Feature can be removed.
- Close MicroStation CONNECT Edition
- Open the Operating System Control Panel (Start > Windows System > Control Panel)
- In the Programs settings select 'Uninstall a Program' to open the 'Programs and Features' dialog
- Scroll through the list of installed applications and select 'MicroStation CONNECT Edition' and then select 'Change' to launch the MicroStation CONNECT Edition installer
- Uncheck 'Descartes' and select Modify.
- Select 'Yes' on the 'User Account Control' dialog
- To verify it has been uninstalled successfully, open a file in MicroStation CONNECT Edition and expand the list of available Workflows, the 'Reality Modeling' Workflow containing 'Descartes' should be missing.
Descartes for MicroStation CONNECT Edition Installation
Need to install Descartes in CONNECT Edition
Other language sources
Italiano
| | Original Author: | Carl Myhill | |
