Application Crashed or Freezes - AutoPIPE
Symptoms and messages displayed when AutoPIPE program stops working properly:
Messaged Displayed:
Item #1: "Bentley AutoPIPE Application has stopped working" A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Item #2:  "Bentley AutoPIPE Application has stopped working" Windows can check online for a solution to the problem
Item #3: Bentley AutoPIPE Application has stopped working: "A problem caused the program to stop working correctly. Please close the program"
Item #4:  Program periodically freezes, toolbars disappear, and application crashes - AutoPIPE V8i 09.05.01.02
Item #5:  Bentley AutoPIPE is (NOT RESPONDING)
Item #6:  The application has failed to start because of IEGLic.dll was not found
Item #7: Microsoft Blue Screen - A problem has been detected and Windows has been shut down to prevent damage to your computer
Item #8: Faulting module name: ntdll.dll
Item #9: AutoPIPE Report Viewer has stopped working
Item #10: Faulting application name: Bentley.Licensing.Service.exe
Crashed when performing:
Question: Is this an valid AutoPIPE model? (click here)
A. Opening a model
i. What to do when AutoPIPE crashes?
ii. Options available to recover a model that was closed before being properly saved
B. Importing / Inserting a model
C. On start-up:
D. Computer Mouse pointer constantly shows thinking status every few moments.
Fix: confirm LMT error checking is turned OFF. see last step on WIKI page HERE.
E. Analyze> All  or Analyze> Static
F. File> Save Stress Isometric All
G. Model Consistency Check
H. Installing
I. Results> Output Report
J. Working with Input / Results grids
K. Viewing Load> Dynamic Analysis Dialog Screen
L. No specific reason
M. Copy / Pasting
N. Modifying / Inserting Components
O. Modifying General / Edit / Results Model Options
Also See:
Warnings, Errors, Crashed, Confirm Messages in AutoPIPE
