| Version(s): | through 08.11.13.140 | ||
| Area: | Administration Features | ||
| Subarea: | Options |
How do I make cross references to normally closed (NC) contacts appear underlined?
If the cross references to the normally closed contacts are still not underlined, ensure that the NC Cross Reference Prefix has been assigned to the normally closed symbols that are being used in the project:
After modifying symbols, be sure to update the project with the new version of the symbol(s) using [[Update Symbol]] or [[Replace Symbol]].
[[Template Project Options]]
