In the 5 videos below, you will learn how to create a workspace folder structure and seed files for the design, drawing, and sheet models.
Product(s): | OpenRoads Designer, OpenRail Designer, OpenSite Designer |
Version(s): | 10.10+ |
Area: | Workspace, Standards |
Creator: | Chuck Lawson, Senior Consultant, Civil Engineering Success Services |
Beginning Dataset for 01 - Folder Structure and Seed Files course
Note: Beginning in the 10.11.00.115 release, instead of editing the "ConfigurationSetup.cfg" file to point to the Custom Configuration location as shown in the video above on version 10.10, the user can use the Manage Configuration command on the startup page to set the location of their custom configuration.
