| Area: | Setup & Customization | ||
| Subarea: | Configuration variables | ||
This wiki explains how to define the config variables at the Organization level. If we want to define the config variables to the Organization level then we can directly use the Standards.cfg file from “C:\ProgramData\Bentley\ProStructures CONNECT Edition\Configuration\Organization”.
1. Open the Standards.cfg from the below path.
Path: C:\ProgramData\Bentley\ProStructures CONNECT Edition\Configuration\Organization
2. Now, define your config variable. For example, I have defined the PS_TEMPLATESLASTUSED as shown in the below image.
3. Now, launch the ProStructures and open the Configuration Variables dialog.
4. Search for the defined config variable and check whether the path and the Level are correctly defined or not.
In this way, one can define the config variables at the Organization level.
