W21-21: Cannot perform this operation, multiple points selected
W21-32: Cannot split segments, maximum number of segments reached
W21-34: This function can only be applied on junction of two segments
W21-38: This function cannot be applied at the current point.
W31-86: No allowable stresses are available for the selected material in the material library
W36-14: Support will be hidden since all gaps > Gap Scale Factor x Pipe O.D.
W79-85: 0 Stiffness in direction of imposed harmonic load. at XXX
W97-99: No analyzed pressure cases present. Only axial GR stress is added
W97-213: Corroded thickness is required for sustained stress in B31.3
W214-1: The combination data file (*.CMB) you are about to open was created in a different version.
W507-14: Modal analysis cannot be performed. Number of modes is zero
W507-40: No temperature case found for non-linear hydrotest.
W726-9: A Guide or Line Stop should not be inserted at following kink point(s)
W726-10: User SIF required at junction at following point(s)
W726-12: Following Segment(s) not connected to other segments and has no anchors
W726-34: Inconsistent coordinates were reset at following point(s)
W726-37: Expansion at (load case) is outside of temperature range at point XXX for material YYYY
W726-38: Allowable at ambient is outside of temperature range at point XXX for material YYYY
W726-39: Allowable at XX is outside of temperature range at point XXX for material XXXX
W726-110: Not all gaps are non-zero for following support(s)
W726-116: Support will be hidden since all gaps > gap scale factor*Pipe O.D.at following support
W726-195: Support D10 1-Zero length from 'supported' to 'connected' point
W726-205: SIF and flexibility factors have not been validated for D/t > 100
W727-2: Temperature is outside the range specified the code for Expansion
W727-3: Temperature is outside the range specified by the code for allowable
W731-6: Tees are not permitted in HDPE pipe system as per CC N-755-1
W2014-35: Previous "to" must be the same as current "from" point
W2018-11, W2018-12, W2018-16: Not authorized for ???? edition, AutoPIPE reverts to DEMO mode
W2143-1 Following inconsistent data found in Analysis Set 1 Number of load cases does not match
W2143-7: The joint information of User SIF or flange will be ignored at following point(s)
W2143-29:Response spectrum case R1 has support group 2 that is no longer defined in model
W2143-37: Extremely high value for Displacement tolerance > 1000 detected in loadset
W2143-41: Undefined case referenced for concentrated force found at point..
W2143-45: A Yield(Sy) value of less than or equal to 1.00000 psi is detected on some points
W2143-108: Stress Range factor > 1 is not allowed for non-ferrous materials. At Pipe(s)
W2164-30: Outside diameter does not match with soil properties at following point(s)
W2164-41:Following inconsistencies are found for rotating equipment xx [yy ,zz ] point included does not have anchor/reference point defined
W2164-58: Soil ID: xxx ,Bedding const. K cannot be zero. Reset to 0.1
W2164-78: D/t ratio for the following pipe ID(s) is less than 20
W2164-93: The value of "Fluid Density Factor" is zero in following analysis sets
W2164-94: The validity of SIF data is only demonstrated for a Do/tn ratio less than or equal to 100
W2164-106: The following pipe ID's are using a depreciated fatigue curve, limited to 1E6 cycles
W2164-125:B31 App J: Crotch radius is less than or equal to zero for the tee(s)
W2164-126:B31 App J: Crotch thickness is less than or equal to zero for the tee(s)
W2164-145:B31 App J: SIF values for the tee(s) below are not valid
W2164-153: B31 App J - The ratio r2/D2 is smaller than or equal to 0.08 for the reducer(s)
W2164-155: B31 App J - The ratio T1/T2 is smaller than or equal to 1.00 for the reducer(s)… warning message occurred in AutoPIPE, why?
W2164-156: B31 App J - The ratio T1/T2 is greater than or equal to 2.12 for the reducer(s)… warning message occurred in AutoPIPE, why?
W2164-159: The value of "Stiffness" or "Spring Rate" is zero
W2164-173:Thickness is out of range of library limits for following pipes
W2164-181: B31 App J: The following tee(s) contain a primary or secondary node on the branch leg
W2164-198:Tee header and branch missing information has been updated on the following point(s):
W2164-204: The following flange(s) do not consider corrosion
W2182-4: Valve/reducer/flex joint should have flanges at both ends
W2182-26: Pressure rating on mating flange to a valve is not the same at point xxxx
W2261-3: Invalid Pipe ID in "Virtual Anchor" data for following Soil Id(s)
W2261-4: Invalid Point in "Virtual Anchor" data for following Soil Id(s)
W2261-9: All stiffness values are zero for the following bilinear support(s).
Warnings, Errors, Crashed, Confirm Messages in AutoPIPE
