Applies To | |||
Product(s): | AutoPIPE | ||
Version(s): | 2004, XM, V8i | ||
Environment: | N/A | ||
Area: | |||
Subarea: | |||
Original Author: | Bentley Technical Support Group | ||
Date Logged & Current Version | Jan 2015 09.06.01.10 | ||
Imported system has disconnected flange on elbow, how to fix this so there is no disconnect?
How to import a model that reduces or fixes these disconnected segments?
When importing a AutoPLANT / OpenPLANT file into AutoPIPE the following dialog appears:
Enable the check-box for " Join disconnected pipe" and enter a "Connectivity Tollerance" value. see AutoPIPE help for details on these settings. Press OK button to use these values. If the disconnect is within the tolerance it will be automatically connected, as shown below:
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
