| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Invalid Cogo Description
User is receiving error message when attempting to Create/Edit Alignment by Cogo Points: "Invalid Cogo Description".
There is a setting in the variable manager that will allow alphanumeric names in Create/Edit Alignment by Cogo Points.
To access the variable manager, you will first need to make sure that it is enabled. Go to Tools > Application Add-Ins and toggle on “Variable Manager Add In”.
Then go to Tools > Variable Manager and toggle on “Geometry – Alphanumeric Names in Create/Edit Alignment by Cogo Points”.
