Luxology Presets and additional Light Probes by Jerry Flynn
The Luxology_Presets.pal that is delivered with MicroStation V8i does not include any of the textures or bump maps used by these materials. These were posted last fall as part of our Luxology beta, along with the many other updates. You will need these textures and bump map files to use the Luxology_Presets.pal, I have posted these file here. Presets_textures.zip Download this file and extract the contents using folder names to your MicroStation V8i workspace folder.
I have also posted several additional HDR Light Probes that were posted to the Luxology beta last year ( you may already have these if you were helping with the beta). These can be downloaded from here. Unparent.zip These should be extracted using folder names to your MicroStation V8i workspace folder so that they will be in a background search path.
These HDR Light Probes are made available courtesy of Keith Bruns and can also be downloaded from his site. http://unparent.com/
JF
