Imperial Bolt or Plate Sizes are Incorrect In Connection Dialogs.
Product(s):ProSteel
Version(s):All Versions
Area:Steel Connections
Subarea:N/A
Original AuthorSteve Crabtree, Bentley Technical Support Group
Updated By:Vyanktesh Nama, Bentley Technical Support Group
Imperial bolt or plate sizes are incorrect in the connection dialogs.
These are steps to fix a problem where you see incorrect bolt diameters or flat bar sizes in a connection dialog.
See figures below.
1.)  Go to the MicroStation Menu - Settings > Design File.
2.)  In the dialog that opens select Working Units from the menu.
3.)  Under Linear Units set Format to MU:SU (Master Unit, Subunit) and click OK.
4.)  Go to the MicroStation menu and select File > Save Settings.
5.)   Exit out of ProStructures and then reopen it.
6.)  If you have a connection that still has incorrect bolts or plates use the connection command to delete the existing connection.
7.)  Reapply the connection and it should have the correct plate and bolts.
