Applies To | |||
Product(s): | MICROSTATION | ||
Version(s): | 08.00.02.20 | ||
Environment: | N\A | ||
Area: | Text | ||
Subarea: | General | ||
Original Author: | Bentley Technical Support Group | ||
Are there keyin's for changing the text and text node justification?
Keyin ACTIVE TXJ or ACTIVE TNJ plus one of the following options:
Justification Setting
Center Bottom CB
Center CC
Center Top CT
Left Bottom LB
Left Center LC
Left Top LT
Right Bottom RB
Right Center RC
Right Top RT
For example to place a text string justified by the Center you would use ACTIVE TXJ CC.
