Where the Manage Configuration settings get stored in ProStructures?
 Product(s):ProStructures
 Version(s):CONNECT Edition (10.07.00.79) & Above
 Area:Setup & Customization
 Subarea:Configuration Setup
 Original Author:Vyanktesh Nama, Bentley Product Advantage Group
This wiki explains where the Manage Configuration settings get stored in ProStructures.
Steps to be follow
The Manage configuration settings are stored in the Configuration.xml file which is located in the below path. Please refer to the below snapshot.
Path: C:\Users\Vyanktesh.Nama\AppData\Local\Bentley\ProStructures\10.0.0\prefs
