| Version(s): | 08.09.04.51 | ||
| Area: | Interchange | ||
| Subarea: | General | ||
Import/Export 3rd party file format list
List of common import/export formats when translating between third party applications and MicroStation.
Product: MicroStation V8 XM Edition
Version: 08.09.04.51
Area: Interchange
You must save the file in the program on the left to the file format on the right in order for MicroStation to be able to import it.
Application: File Format:
AutoCAD -> DWG/DXF
VectorWorks -> DWG/DXF
SolidWorks -> XMT (Parasolid)
Unigraphics -> XMT (Parasolid)
Solid Edge -> XMT (Parasolid)
Mechanical Desktop -> SAT (ACIS)
CADKey -> SAT (ACIS)
Pro/E -> STeP (Solids)
Surfaces -> IGES
Note: This is not a complete list of third party applications. If your application is not in the list check what formats are available to
export to and compare to MicroStation import formats.
