Applies To | |||
Product(s): | MICROSTATION | ||
Version(s): | 08.09.00.92 | ||
Environment: | N\A | ||
Area: | Dimensions | ||
Subarea: | Dim Styles | ||
Original Author: | Bentley Technical Support Group | ||
Dimension settings are grayed out when selecting it from the dimension
styles dialog. Why is this happening?
The dimension style that is selected is from a dgnlib file and is currently not used in the design file. Once the dimension style is used, a copy of the dimension style will be copied to the local file. At this point in time, the settings will then be available.
