| Area: | Template Manager | ||
| Subarea: | N/A | ||
This wiki explains how to identify which template is currently being used in the ProStructures dialogs.
1. Load your template.
2. To check which template is being used, open the Template Manager, and here we can see a grey color background for the recently used template.
NOTE: This grey color background will retain the recently selected template name even though you have not loaded this template. For example, you have selected a template (Group – Rafter) and without loading that you have closed the dialog and when you open the template manager then you will find the grey color background for (Group – Rafter) which is actually not loaded. Here, please make sure that whatever template you load select that one only and then close the dialog.
Currently, this is the only way to identify which template is being used in any ProStructures dialog.
