| Product(s): | Exor Core / Network / Document Manager | ||
| Version(s): | 4.3.0.0 | ||
| Area: | Locator | ||
| Subarea: | N/A | ||
When doing a search in Locator the results are not returned in the correct order. For example our defects available search used to return listing ordered by defect id - earliest first. The result in v4.3.0.0 are random.
The Locator results are now returned with the order they are stored in the table or view as there is no default ORDER BY field. However now you can order them by any of the available fields if you press the field name in Locator Search Results. An ^ or v sign will appear at the beginning of the field name to denote ascending or descending order
