| Product(s): | Power Rail Track | ||
| Version(s): | 08.11.07.536 | ||
| Area: | Geometry | ||
| Subarea: | |||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
I notice that when I display a 3D alignment (Geometry > View Geometry > 3-D Alignment) it is in a different location than when I display a 2D alignment (Geometry > View Geometry > Active Horizontal). Why is that?
MicroStation cannot precisely display a 3D arc. When there is a change in elevation along the arc, the element is no longer a true arc. As soon as you add a vertical element, you are adding a 3rd dimension and there is no way to display a true arc. Therefore, when the element is displayed in MicroStation it must be planarized using stroking.
