![](64b83a324731065088c56642846d43a9.iix)
Faulting application name: Bentley.Licensing.Service.exe, version: 11.0.3.11, time stamp: 0x5cf551d3 Faulting module name: KERNELBASE.dll, version: 10.0.16299.1565, time stamp: 0x99b40eb4 Exception code: 0xe0434352 Fault offset: 0x0000000000014048 Faulting process id: 0x1519c Faulting application start time: 0x01d5ddc10e9d0c27 Faulting application path: C:\Program Files\Common Files\Bentley Shared\CONNECTION Client\LicenseService\Bentley.Licensing.Service.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: 31fe41f1-2323-482a-ba14-b61e49ad64b9 Faulting package full name: Faulting package-relative application ID:
![](f4b8f23a973dc250afb952800153afeb.iix)
Faulting application name: autopipe.exe, version: 12.2.0.14, time stamp: 0x5d8d7ce2 Faulting module name: clr.dll, version: 4.7.3468.0, time stamp: 0x5d490e65 Exception code: 0xc00000fd Fault offset: 0x000ed46c Faulting process id: 0x15358 Faulting application start time: 0x01d5ddc143edc14c Faulting application path: C:\Program Files (x86)\Bentley\AutoPIPE CONNECT v12\autopipe.exe Faulting module path: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll Report Id: 584d8f16-a563-476a-8077-76113d132562 Faulting package full name: Faulting package-relative application ID:
![](b0b836fa477d8250e3378d53636d43d9.iix)
Application: Bentley.Licensing.Service.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: Bentley.UsageLogging.Client.UlasClientException at Bentley.UsageLogging.Client.BaseClient+<MakeRequest>d__16`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].MoveNext() at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(System.Threading.Tasks.Task) at Bentley.UsageLogging.Client.Implementation.PostingClient+<PostClientLogAsync>d__2.MoveNext() at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(System.Threading.Tasks.Task) at Bentley.UsageLogging.Client.UlasClient`1+<PostClientLogAsync>d__121[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].MoveNext() at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(System.Threading.Tasks.Task) at System.Runtime.CompilerServices.TaskAwaiter`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].GetResult() at Bentley.Licensing.LicenseManagement.LicenseManager+<>c__DisplayClass198_1+<<PostClientLog>b__1>d.MoveNext()
Exception Info: System.AggregateException at System.Threading.Tasks.Task`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].GetResultCore(Boolean) at Bentley.Licensing.LicenseManagement.LicenseManager.PostClientLog(Bentley.UsageLogging.ApiContracts.Posting.UsageLogEntry) at Bentley.Licensing.LicenseManagement.ColdUsageHeartbeat.PostClientLog(Bentley.UsageLogging.ApiContracts.Posting.UsageLogEntry) at Bentley.Licensing.LicenseManagement.ColdUsageHeartbeat.PostUsageLogs(System.Object) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.TimerQueueTimer.CallCallback() at System.Threading.TimerQueueTimer.Fire() at System.Threading.TimerQueue.FireNextTimers()
