| Version: | V8, XM, V8i, CONNECT | ||
| Area: | Visualization | ||
| Subarea: | Solar Study |
Solar light or Solar Study is not producing the correct lighting. It seems to be an hour off.
Possible Reason:
The locale in the world may or may not be observing Daylight time for the time entered.
Check what time observance the locale is following and set MicroStation's solar time value to the correct value (Daylight or Standard).
