| Product(s): | InRoads | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Roadway Designer | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Why do I not see all of the templates in the Template Library when the End Condition Exceptions command is selected?
The End Condition Exceptions command is only applicable to End Conditions that the user may edit; therefore, it does not display templates because templates cannot be edited from particular command.
