I get an error message when I save/export a model to DWG.
Error message:
Error creating file [filepath]
This error is standard when the DWG seed file location in pointing to a non-existing seed.dwg file. To solve it do the following:
- Go to Options in the Export File dialog
- Go to general tab and change the DWG Seed File
- Select a valid seed file.
- If not specified by your organization, you can use the one delivered by default [C:\Program Files\Bentley\OpenRoads Designer CONNECT Edition\OpenRoadsDesigner\Default\Seed]
![](24edafe297b18e10afb952800153aff5.iix)
