04. What is the correct ambient temp for use with TTA analysis in AutoPIPE?
Product(s):AutoPIPE,
Version(s):2004, XM, & V8i
Environment: N/A
Area: Load Case
Subarea:
Problem:
WE could have a room temperature in a building, in winter that is not heated where the piping system is located, and the temperature could be 50 F whereas outside it could be -20 F, In this case what would be the ambient temperature?
Answer:
 In this case it will be fair to say that ambient temperature is 50 F i.e. temperature of the surrounding environment where the system is located. This will be used in defining the thermal flux of outside of pipe wall.
External Links
Bentley LEARN Server
Comments or Corrections?
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article to
the "Comments" area below. THANK YOU!
