Customized location of baseplate on Foundation
Product(s):RAM Connection
Version(s):Connect Edition
Environment:
Area: RAM Connection
Subarea: Connection design
Original Author:Abhisek Mandal, Bentley Technical Support Group
In RAM Connection how to model base plate at a customized location like near the edge of a foundation and not in the center of foundation?
You can change the position of the support from the connection pad once the template is assigned. From the dropdown against "position on the support", you can select the option as per your requirement and then fine tune the position using the distance input just below that. See the attached snap for better clarity.
