| Product(s): | Bentley Configuration Explorer |
| Version(s): | CONNECT |
| Area: | Workspace |
Problem:
When using the Bentley Configuration Explorer to work with the OpenRoads Designer "Training and Examples" workspace, the Configuration Explorer issues a Critical Error : "There was a critical error raised in Training-Imperial.cfg on line Training-Imperical.cfg. %if exists (C:\Bentley Training)"
This critical error in Configuration Explorer is issued because it does not (currently) allow a space to be used in any line using an "exists" command. For example, in the above error message, the path specified in the %if exists line is "C:\Bentley Training" which contains a space.
To workaround this issue, the user can define a variable which does not contain spaces to use in place of the path that does contain them on the 'exists' line of the cfg. For example, create a variable named BENTLEY_TRAINING = Bentley Training, then use the variable on the %if exists line: %if exists (C:\$(BENTLEY_TRAINING))
Old config lines:
%if exists (C:/Bentley Training/)  MS_DEF = C:/Bentley Training/%elif exists (D:/Bentley Training/)  MS_DEF = D:/Bentley Training/%else  MS_DEF = $(_USTN_WORKSETROOT)/dgn/%endif
New config lines:
BENTLEY_TRAINING = Bentley Training%if exists (C:\$(BENTLEY_TRAINING)) MS_DEF = C:/Bentley Training/%elif exists (D:\$(BENTLEY_TRAINING)) MS_DEF = D:/Bentley Training/%else MS_DEF = $(_USTN_WORKSETROOT)/dgn/%endif
In this example, the folder name that contains a space "Bentley Training" is replaced with a variable name that does not contain a space "BENTLEY_TRAINING" but ultimately points to the same path after the variable is resolved.
Note: Other configuration files will require editing as well.
