SignCAM Rotate Selected
Question:
How do I rotate a diamond sign in OpenRoads SignCAD to save material when cutting?
Answer:
1) From the Preferences menu in OpenRoads SignCAD, pick Rotate Angle.
2) Set the Rotate Angle = 45 and press OK.
3) From the Preferences menu, pick Allow Panel Selection.  Use the Select tool to window select the diamond sign.
4) Pick SignCAM>Rotate Selected.
5) Select the rotated sign and pick SignCAM>Cut Selected to cut it.
