| Product(s): | ProSteel | ||
| Area: | Steel Connections | ||
| Subarea: | Bracing Connections | ||
This wiki explains how to properly cut the extended gusset plate in the dynamic bracing.
1. In the Bracing dialog, click on the Add Cutting Edge button.
2. Now, select the new border line for bracing at the bottom of the beam as shown in the image.
The result of this will be as shown below.
In this way, we can cut the gusset plate correctly in the dynamic bracing.
