| | Product: | MicroStation | |
| | Version: | V8, XM, V8i | |
| | Environment: | N\A | |
| | Area: | Dimensions | |
| | Subarea: | Dim Styles | |
Using the joint terminator for a dimension line in a single row
- In the Dimension Style setting dialog , under the tab "Geometry", > Fit Options > Text/Terminator > select "Term Reversed"
- In the Linear Dimensioning tool setting ,you can change the "Location" to "Manual"
See also
Other language sources
Deutsch
| | Original Author: | Judy Wong | |
