| Version(s): | 10.14.00.86 | ||
| Area: | CONNECT Advisor | ||
| Subarea: | N\A |
CONNECT Advisor window pops up each time MicroStation is started, even though the automatic start is turned off in CONNECT Advisor settings.
Perform the following steps:
1. Open Notepad as an Administrator.
2. Right click Notepad and “Run as Administrator”
3. Open file “C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\system\applicationload.cfg”
4. Search for “ConnectAdvisor”You will find this line “_USTN_FIRSTDGNFILE > ConnectAdvisor”
5. Add a Hash symbol “#_USTN_FIRSTDGNFILE > ConnectAdvisor” to the start of the line
6. File > Save
| Original Author: | Grzegorz Cwiek |
